Modular V10 (6.8l)
What the heck?
Old 04-13-2016, 09:05 AM
critterf1's Avatar
critterf1
critterf1 is offline
What the heck?
I have a 2000 V10 with the most awful spark knock you've ever heard. Fuel pressure within spec and exhaust has no restriction. Knock sensors ever go bad?
Old 04-13-2016, 09:42 AM
harley4jcs's Avatar
harley4jcs
harley4jcs is offline
I'm not sure what you mean by spark knock BUT is it possible it may be trying to spit out a plug ??
Old 04-13-2016, 09:50 AM
critterf1's Avatar
critterf1
No it's not trying to spit a plug. They're new and seated properly. Detonation is what I'm talking about. Pinging
Old 04-13-2016, 09:51 AM
critterf1's Avatar
critterf1
No codes present and it does it regardless of brand of fuel or octane used.
Old 04-13-2016, 09:58 AM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
Could be knock sensor. Do you have a chip/tune on it? Air filter clean? Fuel filter good? Anything you can think of that would make it run lean?
Old 04-13-2016, 11:05 AM
harley4jcs's Avatar
harley4jcs
Those are 2 terms I DO understand & the only ways that I know they can be caused is by ,the timing being too advanced, Engine under severe load with the crap they sell as gas now a days,Or using a low octane fuel in a high octane required engine....
Old 04-13-2016, 11:41 AM
weeeves's Avatar
weeeves
weeeves is offline
I'm not familiar with the V10's, but do they have VVT (Variable Valve Timing)? My Lincoln had the worst pinging I've ever heard at full throttle which was due to a bad VCT solenoid. It took me awhile to track it down. Disconnecting the VCT solenoid eliminated the pinging completely.
Old 04-13-2016, 01:03 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
Is the pinging accompanied by a loss of power, especially at higher RPMs? If so it could be a clogged catalytic convertor, checking the pressure at a pre-cat O2 sensor will be the best check.
Old 04-13-2016, 01:20 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Moved over to the V10, 6.8L modular engine forum.
Stewart
Old 04-13-2016, 02:23 PM
critterf1's Avatar
critterf1
Severe loss of power. Installed my back pressure gauge in up-stream O2 bung, readings are normal. Any thing above 1/2 throttle is terrible.
Old 04-13-2016, 02:28 PM
High Cetane's Avatar
High Cetane
High Cetane is offline
Did this symptom occur prior to changing the plugs ?
What plugs did you install, ie: are they the correct plugs?
Old 04-13-2016, 02:32 PM
truckfella's Avatar
truckfella
truckfella is offline
Did this issue arise at the same time the new plugs were installed? I assume not, but had to ask anyway.
Is check engine light on?
Are all cylinders detonating? Or just one or two?
Old 04-13-2016, 02:43 PM
critterf1's Avatar
critterf1
Before new plugs, no codes and it sounds like every cylinder
Old 04-14-2016, 05:20 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
I had the same issue last year. Catalytic a converters bad.
Checking at the o2 bung won't find it because the back pressure is between the 1st cat and the engine.
Unbolt your exhaust. Look inside with flashlight.
Test drive with exhaust disconnected.
You'll see.
Old 04-14-2016, 06:48 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
You never answered what plugs you swapped in. Also you might think about running non-ethanol fuel in your truck. It's all I run unless I run low and can't get to any.
Quick Reply: What the heck?
