Misfire codes
Old 04-08-2016, 03:53 AM
Sharkster54's Avatar
Sharkster54
Sharkster54 is offline
Question Misfire codes
Hey guys, I recently picked up a 2004 Mercury Mountaineer, 4.0 with 113,000 miles.
OBD reader says misfire on 3 cylinders.. Installed new plug wires first.. nothing.. going to install plugs next when she is cold. Now, am I really looking at replacing the coil pack to end the misfire codes? She likes to buck and shake and idle around 400 rpms.. I know that is too low..
I figured someone here has already been down this road and I'm looking at how much this might cost.
Many thanks guys!!
Old 04-08-2016, 06:52 AM
shorod's Avatar
shorod
shorod is offline
Which 3 cylinders are listing a misfire? If all 3 cylinders are on the same bank, it may be something other than plugs and wires, such as a vacuum leak or fuel injection wiring harness....
-Rod
Old 04-11-2016, 10:39 AM
Chugalug's Avatar
Chugalug
Chugalug is offline
-Rod
Or maybe timing chains. Which was the case with mine.
Same symptoms as mine. Mine had about 117k miles at the time.
Old 05-01-2016, 11:33 AM
Paul Chase's Avatar
Paul Chase
Paul Chase is offline
Paul chase
I have a 94 explorer I had to replace the brain. The camshaft position sensor. Egr valve.about sixteen hundred in parts and labor. The c.e.l. went out long enough to get it smoggged.after finding out the c.e.l.t burned out I replaced I replaced it. It came on and stays on .I performed the e.o.e.r. test and got a 337 code. I was going down the road at 45 mph when I noticed the cel light had gone off this lasted 20 sec or until I decelerated and it came and has stayed on.the question I have is this is that 337 code being caused by the egr valve or some other vacume problem? I just hate the process of elimination that is expensive. Any advice is appreciated greatly.
Old 05-01-2016, 05:55 PM
shorod's Avatar
shorod
shorod is offline
The code 337 points more to the DPFE sensor than an EGR valve itself. The DPFE was actually a pretty common issue on older Fords.
-Rod
bduke23
08-08-2018 11:05 PM
Bootlegger's Deluxe
Modular V8 (4.6L, 5.4L)
03-12-2016 08:51 PM
XR4TiSam
1997 - 2003 F150
11-05-2015 11:47 AM
richis69mach
1997 - 2003 F150
04-20-2010 11:00 PM
cardio75
03-05-2004 07:50 PM
Quick Reply: Misfire codes
