Transfer case stuck oin neutral?
Old 04-02-2016, 09:42 PM
Bio-Vic's Avatar
Bio-Vic
Bio-Vic is offline
The 4x4 has not worked on my 4x4 Explorer Sport Trac for several years!
I removed the Transfer Case Shift Motor, took it apart and cleaned it thoroughly and then I re-installed it.
I turned the truck on put it in Neutral and then moved the switch to 4X4 High... for the first time in a long time I could hear the click underneath the dashboard/floorboard like if it was trying to engage... it did it three or four times and then I switched it to 4X4 Low and it engaged! The little light came on. I tried to back out of the garage and I can hear the transmission shift but it did not move!
I put it in Drive and I can hear the transmission shift over but nothing. The engine would rev up but it wouldn't move forward. I tried putting it in park and it sounded like it grinded gears.
I unplugged the battery for 20 minutes and tried all of this again and nothing.
I got underneath and turned on my cell phone camera under the transmission and repeated the same steps above. I could see the shift lever on the side of the transmission from the column move through all positions.
I tried to push the truck out of the garage in Neutral and I cannot push the truck at all!
Is my transfer case stuck in Netrual? Did fuses blow? I can't leave the garage open all night... any advice would help out!
Bio-Vic
05-19-2023 07:30 PM
Bio-Vic
04-05-2020 07:27 PM
jem44357
01-27-2010 09:13 AM
BillF150XLT
1997 - 2003 F150
06-24-2003 06:06 AM
Quick Reply: Transfer case stuck oin neutral?
