OBS Crew Cab Diesel guys?
#46
Mike gave you a great list of items to review. Check those out. I will add a couple.
You mentioned drivability on a 60-mi commute. I assume the 37" tires won't be 60-mi commute tires for long. So research good replacements, and check the gearing. The ZF5 doesn't have an especially fast overdrive. I've only driven one other of these trucks besides mine and that test drive had the 4.10s. I was surprised the RPMs it had to turn to maintain highway speed.
There are a couple great threads on this forum about pedal bushing and seat repair (thanks to the original author's Aaron and Neal). Worn out seats and pedal bushings seem common with these. They're low-buck fixes but are a pain. However having the seat shored up and the pedals tight go a long way to restoring drivability and comfort. Links:
https://www.ford-trucks.com/forums/1...-seat-fix.html
https://www.ford-trucks.com/forums/9...pic-heavy.html
Lots of little things like these really add up to making for a tighter newer feeling truck that is more comfortable as a daily driver.
Even with upgraded steering components and good alignment seems like a slightly loose steering feel is still pretty common with these. Best to try it out and see how comfortable it is to you.
#49
#51
Thank you. My 96 bronco had a lot of these problems itself.
#52
#53
There appears to be a very clean white red interior 95 cclb dually up the street from me...I will text you the 1 picture... I got of it...
#54
OK so I'm still on the hunt. I have drove a few and found out that people are super proud of these trucks and are not will to cut much of a deal on them. lol
I'm heading down to Texas this week to look a super clean 97 F250... no a diesel this time it's the 460.
What can you guys tell me about the gassers?
Also it has 4.10s in it. How do these trucks run on the highway with them?
#55
#56
#57
This is all very true.... I believe mine got a consistent 8 mpg (fuel injected)....
Fuel injected 460's tend to brake exhaust manifold bolts.....
#58
#60
