Coolant Leak In Cab
Old 03-29-2016, 03:36 PM
treverd's Avatar
treverd
treverd is offline
Coolant Leak In Cab
1971 F100 360 (No AC)
Steam coming from vents, antifreeze smell inside truck.....heater core leak.
Luckily no AC in the truck.
I am in the process of rebuilding the heater assembly (new heater core, damper foam, seals, etc).
While the heater core was leaking it got some behind the rubber floor on the passenger side. I am afraid if I do not dry it up, the floorpan will rust quick.
What is the best way to dry up that firewall and floor pan?
Is the rubber flooring on that side easily removed to get under it?
Thanks Guys,
Trever
Old 03-29-2016, 04:02 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Yep undo the door sill trim and dry 'er out.
Old 03-29-2016, 10:12 PM
treverd's Avatar
treverd
treverd is offline
As always, thank you HIO.
Old 03-30-2016, 09:31 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Actually as long as it was coolant it'll slow or stop the rust, green anti freeze has anti rust additives to keep the inside of the block from rusting away. It'll just smell bad.
Nine6Teen
10-31-2017 10:04 PM
mikeberman04
01-01-2008 11:59 PM
Cruiseomatic
12-13-2005 07:34 PM
Fordtrucktexan
1997 - 2003 F150
04-15-2003 10:43 AM
24hourcampfire_com
1983 - 2012 Ranger & B-Series
03-25-2003 09:48 PM
Quick Reply: Coolant Leak In Cab
