I-Beam Question
I-Beam Question
I have a 66 F250 that I wish to lower (1-2 inches) without replacing the original I-beams. Is it possible to lower the truck/chassis 1-2 inches with different springs/shocks? I'm not interested in replacing I-beams with DJM 3 inch drop beams or switching to IFS. Trying to get the truck a tad lower using the original i-beams. Thanks for any/all responses.
The only way to lower your truck without using lowering beams would be to run shorter coil springs. However, the camber of the front tires is set by the height of the springs. If you start shortening the coils, you begin to induce negative camber into the wheels/tires (the front tires will lean inward at the top).
The only correct way to lower the truck is to install lowering beams.
Thanks for the feedback. One follow-up question...suppose I went with the lowering i-beams (like DJM 3 inch drops), is it possible to add 1-2 inches back to the ride height...and do it safely and in a mechanically sound way to avoid the camber issues? I know this may seem like odd questions, but I'm trying to get as much information regarding my options so I can make the best decision for our needs. Thanks again.
You MAY be able to add or subtract some minor amout of spring height to adjust the overall vehicle height. Too much reduction though will result in negative camber, which is going to chew up the inner edges of the front tires. Too much addition to the height is going to result in positive camber that's going to chew up the outer edges of the tires.
It would probably be best just to contact DJM tech support and ask them what your options are, and what you're wanting to do, to see what they say can or can't be done.
Here is a listing of all the beams they make, they list two that will prob work, but you need to know your kingpin OD to select the correct one....
List of all beams
Dropped Lowering Spindles, Lowering I-beams | AirBagIt
List of all beams
BTW: I understand that Sid Drapal, from Nostalgia Sid's/droppedaxles.com is slowly working on fixtures to enable him to drop the factory forged twin I beams. No ETA, as this is stricly a "spare time" project, and he stays plenty busy with work in the shop, plus attending events as a vendor....
I sure hope it's not YEARS away, as I am interested, but when I get to the point where I'm ready, if the beams are not, I may be forced to go another route.
I just emailed Sid
To see if he will be dropping twins anytime soon. I have heard that rumor in the past, hopefully it's not a rumor now. I'll let everyone know what he says.
I did lower 2" in the front cutting the springs and it did cause noticeable negative camber, but I only put 100 miles on my truck a month.
CooGAR
01-10-2011 08:06 PM
71fordkid
01-14-2008 01:35 PM
OneSweet81
02-16-2006 12:35 PM
