Mishimoto Thermostat in Sinister Diesel Housing?
If the sinister housing is designed to fit the OEM thermostat, then I don't see a reason it wouldn't work. If you take the current t-stat out and the length matches the mishimoto, you should be fine.
I had a cheap autozone housing in my truck when I went to install my mishimoto t-stat. It wouldn't fit and the autozone t-stat was a bit shorter. After buying a motorcraft t-stat and housing, (they wouldn't sell me just the housing and I threw away my motorcraft when I put in the autozone) the mishimoto went in just fine.
gary's1950F1
11-29-2017 12:53 PM
