1949 M-68 (F-3) Modern aftermarket rims
Old 06-17-2016, 03:05 PM
zrae's Avatar
zrae
zrae is offline
The local kal tire where I live is able to order an after market rim for around$250 a piece. They said it will bolt right onto the existing rear end. I haven't bought them yet so I am not 100% certain if they will fit or not. LMC truck sells an after market 17" 8 bolt rim also. I saw it in one of their catalogues.
Originally Posted by Jeffrey Rempel
I have done a lot of reading and searching on this form and I can't seem to find any reference to current production aftermarket wheels that will fit on a 1949 Mercury M-68 (F-3). Have I just missed them or are there none available? My truck has what I believe to be widow makers (maybe someone can confirm?) and I would like to replace them with something safe.
  #32
Old 06-17-2016, 03:24 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
I don't see it in their online catalog. As long as it has a center hole to clear your 4.75" hub, and about 1/2" of positive offset you'll be okay. Hub cap mounting, though, might be an issue. Post a pic from their print catalog if you can. Stu
  #33
Old 06-21-2016, 05:56 PM
zrae's Avatar
zrae
zrae is offline
So this is from the catalogue that ended in April or May. So it's a couple months old. The only is it doesn't say the center hole. So I am not sure if it's right or not. Like I said before, I haven't ordered them so I am not 100% certain.
Go Fly
07-24-2018 12:30 AM
Robhudson
06-10-2015 11:23 PM
ojh
18
11-04-2013 10:46 PM
pgh49ford
21
03-29-2011 06:55 PM
2bocat
08-10-2005 12:16 PM
Quick Reply: 1949 M-68 (F-3) Modern aftermarket rims
