F250 Rear pins and shackle bushing questions
Joe,
I was looking for something else and ran across these. Thought I'd post em. 53 - 56 Ford Truck Rear Swing Hanger - Rear Suspension - F250
I removed one of the bushings from a spring. That wasn't too hard with the bushing removal tool and a BFH. I heated up the spring a little.
To get the new one in, I put it in the freezer for a while then heated the spring.
This morning I ran out to Orschlen's and got some threaded stock and a couple washers and nuts. That combined made for easy install.
It went very smoothly. I was worried about getting the new ones in.
I also received my new shackles today.
So, does it matter which way they go? Should the spring lock pin go close to the frame our can it go on the outside?
Mine was close to the frame, but wouldn't it be easier to install the pin if it was on the outside. Would that cause problems?
I haven't checked to see if the shackle pin will go in only one way or not.
Oh, shoot! I was thinking you can put the pin in either way, but now that I think about it, you are correct. That would not be good. OK, I'm just glad I didn't try it before I got to think it through with everyone's help.
55RoundTwo
06-25-2019 11:01 PM
windsor8689
01-10-2011 08:18 PM
