Question about wooden side racks
Old 03-27-2016, 10:49 AM
fbb1951's Avatar
fbb1951
fbb1951 is offline
Home made oak racks.
Bolted in.
Old 03-27-2016, 11:09 AM
Harrier's Avatar
Harrier
Harrier is online now
Wow! Beautiful racks and beautiful truck.
Old 03-27-2016, 12:09 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
Thanks, Brent. That is something like I had in mind. Since I will not be hauling pigs or cattle would I really need the boards across the front? Or are they needed for stability?
Brent, are your 2 x 2's tight against the stake pocket or do they go the whole way to the bottom?
Old 03-27-2016, 03:08 PM
fbb1951's Avatar
fbb1951
fbb1951 is offline
abe, I just liked the look with the front boards, plus it ties both sides together for stability. The 2x2's are full depth and bolted through the stake pockets. There in there really tight, hope I don't have to remove them. I seem to do overkill on everything.
Old 03-27-2016, 03:11 PM
abe's Avatar
abe
abe is offline
Also, did you use stainless bolts and hardware?
Old 03-27-2016, 03:16 PM
fbb1951's Avatar
fbb1951
fbb1951 is offline
Yes, all stainless hardware. Be sure to use anti seize if you go stainless.
Old 03-27-2016, 03:26 PM
abe's Avatar
abe
abe is offline
Do your 2x2's go to the bottom of the stake pocket or do they wedge tight against the stake pocket?
Old 03-27-2016, 03:40 PM
fbb1951's Avatar
fbb1951
fbb1951 is offline
abe, The 2x2's are full depth and bolted through the stake pockets.
They go to the bottom.
Old 03-28-2016, 04:46 PM
CBeav's Avatar
CBeav
CBeav is offline
Just a heads-up on stainless and anti-seize. The one thing I dislike using more than anything else is anti-seize, it seems to get all over everything. When it comes to stainless fasteners you can use Milk of Magnesia to coat the threads and prevent galling. (cleaner and cheaper) It used to be the only approved anti-seize agent approved by the FAA.
One other thing, the red or white band on brass threads (fittings, etc.) is not sealer but an anti-galling agent. For good sealing use the appropriate sealing agent when assembling - thread tape, brush on sealer, etc.
Old 03-30-2016, 02:29 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
A modern version I came up with
Just 5
06-08-2014 10:40 AM
RL250
04-04-2014 09:34 PM
projectbad78
Paint & Bodywork
04-14-2008 06:43 PM
saftman
Paint & Bodywork
06-12-2006 02:42 AM
parks911
Paint & Bodywork
04-05-2004 11:35 PM
Quick Reply: Question about wooden side racks
