Question For The Masters
Old Apr 4, 2004 | 09:25 PM
parks911's Avatar
parks911
Talking Question For The Masters
What grit of sandpaper do I used to wet sand a single stage enamel?
Old Apr 4, 2004 | 11:15 PM
parks911's Avatar
parks911
I also forgot to ask how long should I let the paint cure before wet sanding?
I am going to be using hardener with the single stage enamel.
Old Apr 5, 2004 | 12:51 PM
Aekisu's Avatar
Aekisu
<cr>
Why are you sanding? Is it to fix defects or for a repaint?
Old Apr 5, 2004 | 02:44 PM
parks911's Avatar
parks911
Originally Posted by Aekisu
<cr>
I am wanting to wet sand & buff after painting.
I was told that this will remove minor imperfections & orange peel.
Old Apr 5, 2004 | 05:24 PM
Aekisu's Avatar
Aekisu
<cr>
You're right, it will remove defects and you're lucky you are using a hardener or you would be waiting weeks.
I've never tried it on hardened enamel so I'll just tell you what I do with urethane.
After painting, I wait 24 hours and then I sand. After sanding, I let the car sit for a week before I buff. This seems to work best for me but others don't wait quite as long.
Anyone out there worked with hardened enamel and can help out ?
Old Apr 5, 2004 | 11:35 PM
GABRIEL's Avatar
GABRIEL
For enamel with hardner, I would wait 2 to 3 weeks before I would try to sand and buff. It still needs time to dry and harden properly.
If u just have minor imperfections, try using 1000 grit. That should be plenty fine and yet be course enough to remove any dirt/orange peel.
Be very careful when sanding. Make sure u have plenty coats of paint (3 medium coats when properly sprayed is more than enough). Then use caution when sanding/buffing. Enamel sands very easy and same with buffing. U do to much of either and u just might have to repaint!
