1993 F350 4x4 Rear Disc Brake Conversion
No, they are hydraulic. The cable lever is for the parking brake function.
As far as conversion, are you doing this for looks or increased braking? The minimal gain in braking will not be worth the money and time invested in this conversion. Most of your braking power comes from the front brakes. The back brakes don't do much (10 to 20% at most) except keep you lined up during a hard panic stop.
I did this conversion to a '73 International 1010, adding discs off the front of Ford Ranger and those GM calipers. It was a bear, since a kit wasn't out at that time. Increase in braking? Negligible. Had to change out the Master Cylinder, had to try four of them to find one that worked good with the conversion. Wasn't worth it.
I would just have the drums turned, buy some premium shoes and call it a day. Much cheaper and easy to fix on a trip. I have observed first hand the failure(!) of a caliper bracket on a converted '96 F250. Try to fix that on a Sunday evening, out in some small rural town. We couldn't.
Just sayin', since you need skills and possibly access to a good machine shop to do a conversion like this. I'm not sure you will find a true "bolt-on" kit that requires nothing but hand tools to accomplish.
My $0.02 USD worth. Maybe others will chime in with their experiences.
This gets asked pretty often here. Do a search and you'll find what's been said before. Here is the most recent thread (from all of 4 days ago) https://www.ford-trucks.com/forums/1...disc-swap.html
Doing it for looks? Whose going to see it?
Received 3,108 Likes
on
I converted mine about 2 months ago. I haven't looked back since. Stopping power is night and day over the stock drum setup. New rotors front and back with ceramic pads and my truck can stop on a dime now no problem. I used ruff stuff specialties kit and it bolted on no problems in about 2-3 hours time including pulling out axles, installing new Scotseal XL hubs, flaring brake lines and topping off gear oil.
Kit is $396 shipped to your door
then you need:
Brake line fittings 2 3/16" $5.00
Hub socket if needed $25 amazon
Scotseal XL rear hub seals $45 Napa, got mine on ebay $25 ea
Brake fluid $10
1 can of paint to paint calipers and brackets
grade 8 hardware to bolt up brackets $15-20 at lowes
Some say 94 + axles need to have caliper bracket backspaced 1/4"
mine is a 92 and it had to be spaced so just check before all done.
then you need:
Brake fluid $10
right now I don't have it hooked up, but you can get it to work with el dorado calipers from the 70's. I never use mine so its not a concern to me.
Pedal is nice and firm always, stops on a dime and easier to service.
then you need:
Brake fluid $10
then you need:
Brake fluid $10
Did you use a proportioning valve for the rear or just hook the kit up and go
Got my kit sitting in the garage waiting for me to have some time
