Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1974 F-600 dump help
Old 05-27-2016, 02:59 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
The back side of the fuel pump can leak directly into the crankcase. If that is happening, it will be evident when you pull the pump. Try to preserve the metal fuel lines between the pump and carb. They sometimes get bent or twisted. They are much safer than the usual auto parts store rubber hose.
A failed needle and seat in the carb can also drain gas down the intake and past the rings.
Grinding into 1st and R is normal. These are non-synchro gears. You can, as suggested, hold the clutch a little longer before pushing into the gear. Or, you can just run the trans into 4th or 3rd or whatever your pattern makes easiest, then go directly into 1st or R. The engagement of one gear stops all the twirly bits from spinning in the trans, making engagement of 1st or R easier despite the lack of a synchro.
  #47
Old 06-03-2016, 08:04 PM
finn's Avatar
finn
finn is offline
The fuel pump has a rubber diaphragm that cracks and leaks fuel via the lever that runs off the cam lobe and subsequently contaminates the lube oil.
Typical failure on a carbureted engine in the old days.
  #48
Old 05-26-2017, 09:54 PM
Brownryan90's Avatar
Brownryan90
Brownryan90 is offline
Anybody have an answer for why it runs good for 20-30 mins then decides to stall out and not want to start unless it sits for another 15 mins?
  #49
Old 05-27-2017, 05:38 AM
Spirit of '76's Avatar
Spirit of '76
Spirit of '76 is offline
Could be your coil going bad. Next time it happens try this test;
  #50
Old 07-18-2017, 09:53 AM
B.sierra's Avatar
B.sierra
B.sierra is offline
Hi, I need help with my 68-76 dump vin
  #51
Old 07-18-2017, 07:08 PM
85e150's Avatar
85e150
Welcome to FTE. Your question was answered in the other thread you posted in:
https://www.ford-trucks.com/forums/1...-decode-9.html
TicketMan4u
Large Truck
17
04-14-2019 07:20 PM
gdirienzo
08-20-2018 05:00 PM
JakeK
03-04-2018 05:59 PM
Brownryan90
07-15-2016 05:45 PM
Brownryan90
03-08-2016 03:24 PM
Quick Reply: 1974 F-600 dump help
