New heater/vent/issue
Old 03-06-2016, 06:21 PM
PJ-Hunter's Avatar
PJ-Hunter
PJ-Hunter is offline
I have an 03 F250 7.3litre. I have noticed the last few times driving while hauling that my vents start pushing hot air when under a load (example: driving up a long,steep pull) even if I have the AC on. It's starting make me a lot hot under the collar (pun intended)
Any advice?
Old 03-06-2016, 06:42 PM
Sous's Avatar
Sous
Sous is online now
Received 4,464 Likes on 2,853 Posts
Search for "A/C shim" on the forum and watch the video below. This is likely your problem.
Old 03-06-2016, 07:07 PM
PJ-Hunter's Avatar
PJ-Hunter
ok. I'll check that out when weather clears. But yesterday going to Denver I was just running the vent and while climbing with my trailer it started blowing hot. Then of course once the hard pull was over the vents started blowing cool again. This did it with the AC on later in the day, but then AC cooled off once the hard pull was over. So I get the shim part but why is it doing it if I'm not even running the AC?
Old 03-06-2016, 08:02 PM
Sous's Avatar
Sous
Sous is online now
Don't quote me on this, but I believe that the A/C is always running, except when you have it on defrost on the windshield. I know the A/C is running most of the time, despite the temperature setting, but I cannot remember for sure which setting it is not running in.
Old 03-06-2016, 08:07 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
IIRC ac compressor only runs in ac, max ac and defrost. Next time it happens reach up and see if air is being diverted to the defrost vents. This would indicate your losing vacuum and the blend doors are closing. Not sure how a hard run could cause it though.
Old 03-06-2016, 08:22 PM
PJ-Hunter's Avatar
PJ-Hunter
How involved is that to address the blend doors. And my AC runs when I have it on the Vent/Floor setting too. Always has.
And the air still was blowing out the panel vents, wasn't being diverted
Old 03-06-2016, 08:51 PM
AllaboutMPG
if it was still blowing from the vents then it is not a vacuum problem. waiting now for someone who has had a similar problem
Old 03-07-2016, 11:44 AM
Baatzy's Avatar
Baatzy
Baatzy is offline
I'm leaning towards the AC clutch issue like Sous pointed out, makes sense. While cold/cooler, clutch engages fine. When warmed up/hot the clutch has issues staying engaged.
Just my 2 cents,
Baatzy
Old 03-08-2016, 06:44 PM
PJ-Hunter's Avatar
PJ-Hunter
Photos
Just my 2 cents,
Baatzy
Well, I gauged the gap. It's pretty wide. Certainly nowhere near the 0.02 that the video recommended. I'll fix that tomorrow night. Should help, I hope
Old 03-08-2016, 07:07 PM
Sous's Avatar
Sous
Sous is online now
Keep us posted. I had a very similar issue and removing a shim helped and eliminated the humid/hot air being put out through the vent. I ended up having refrigerant checked and topped off, but the real fix was the shim.
Old 03-14-2016, 09:29 AM
PJ-Hunter's Avatar
PJ-Hunter
So the shim didn't fix the problem. AC blows a lot colder but when I start pulling up long, steep grades she starts to blow hot. I have to turn off the temp control and roll window down. Water temps are reading fine, not throwing any codes. Soft or hard.
I'm at a loss.
Old 03-14-2016, 09:36 AM
Sous's Avatar
Sous
Sous is online now
Well, it could be the refrigerant is low. I had mine checked just to be sure the system was in top shape even after adjusting the shim space.
Old 03-14-2016, 09:57 AM
PJ-Hunter's Avatar
PJ-Hunter
Is that something I can do by buying a refill kit at the parts store? Not too many trustworthy shops here and the people they hire are only here in this area to make enough cash to buy and smoke pot. Isn't Colorado swell?
Old 03-14-2016, 10:22 AM
Sous's Avatar
Sous
Sous is online now
You can try it, but I usually leave it to the professionals and pay a bit more for the service with the proper gauges and devices to get the job done right. Although, I have a very reliable shop to take my vehicles to that I trust.
Old 03-14-2016, 03:13 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Hummm...I think I suggested to check your freon in the other thread. The air gap check is for if you have consent warn or hot air. Since you have cold and hot you have a different problem.
Yes you can fill your freon yourself. Get the AC Pro at any parts store. Very easy to do with great instructions. I did mine last year and works great.
Quick Reply: New heater/vent/issue
