I'm going to be replacing my Stock injectors and I want the new set to be stock as well. So the big question is, is it worth spending the extra $800 for new injectors over the Re-manufactured ones ? Also who do you guys recommend buying from??
Kevin
I have a Single Shot Stage 1 set that I just put in.
I swapped over from split shots and so far I haven't had any issues! I looked and looked and from what I found remand are just as good as new otherwise a lot of guys wouldn't stand behind them the way they do.
These guys believe in what they do and it seems like a lot of others follow along for a good reason.
In the end it is up to you bud. I say if you can afford it and want the extra security get new but if you are okay with the idea of remains and want to save the money go reman! There really isn't a bad choice my friend. At least not from what I've found.
I was lucky enough to have a spare set laying around. Sent them to Rosewood for a full rebuild and upgraded to AC 160 SS's.
Close to 50k miles on them and not one issue.
