Have an 05 f250 that sometimes locks when coming out of a turn. Pretty scary when it happens. Universal joints are not seized. (jacked truck up and locked the hubs and tuned the wheel and both turn and rotate freely)
Did your turn the steering wheel lock to lock and rotate the wheels as well? This will best determine if you have a bad u-joint. If you just rotated the wheels while the steering is straight ahead, you are not flexing the u-joint.
I can't determine if you turned the wheel/tire assembly or the steering wheel.
