Upfitter switch for flashing clearance lights
Flashing back the "thank you" when passing a semi. Most big rigs and buses will have a "flash" switch to flash the clearance lights without affecting headlights. Just curious if anyone has thought of this with their SD since you can't flash the clearance/running lights without turning off your headlights.
Here's a question: will flashing the clearance lights by themselves on the truck also have the same effect on the trailer (clearance lights only flashing) or is the trailer wired such that all of the running lights are on the same circuit and wouldn't flash if you clicked your new button that flashes clearance lights by themselves on the truck?
Would you have to isolate the trailer's clearance lights somehow and then feed them from your truck's clearance lights to get the desired effect? I'm slightly interested and may do it on my 7x18 enclosed bike hauler if it wasn't a huge PIA. Have an upcoming Florida vacation planned and this would be a cool feature. But not cool enough for me to mess with my trailer lighting outdoors in 20 degree weather.
For "come on over" turn your headlights off, then on.
For "thank you" flash your hazards three or four times.
Stay inside, cozy and warm, don't jack your lights up and be that guy driving down the road with one really bright tail light that goes dim when he steps on the brake.
As far as I know, roof clearance lights, mirror clearance lights, tail lights, and parking lights are all on the same circuit, operated by one switch.
The last thing I want to do is jack up the lights, and hazard switch is ok, but there's an obvious thank you with the running lights. Very intrigued about tapping into the cab lights but wondering if that will also affect headlights. Wondering about tapping into the 7-pin running lite contact which I could break directly with an upfitter switch so I'm only flashing the trailer lights. Or I could just stick with using the hazards.
