4.2 V6 - totally confused about getting the right intake manifold gasket
2003 E150, 4.2 V6 - 135,000 miles - planning to drive this cross country and back.
So I need to replace my isolator bolts, and with all the reports of coolant leaking into the engine through the intake manifold gasket I plan to do that too so I can have the peace of mind given this vans milage.
But there are two intake manifold gaskets
1 - Fel-Pro MS94452 Manifold Gasket Set
#1 is the one shown in most of the Isolator bolt instructionals
Which one is the culprit for the coolant leak issue?
if it is #2, how much more difficult is it to access if I am already replacing the isolator bolts?
2 - Fel-Pro MS95985 Manifold Gasket Set
#2 is where a coolant leak would develop, the upper manifold gaskets are dry and never see coolant.
thanks for this explanation and the picture, very helpful. Does anyone have any opinion on how much more of an effort it is to replace the lower intake manifold gasket?
Like, If I'm already doing the upper, and the isolator bolts, can I just as easily remove this intake manifold and do the gaskets? I just want to go into it with realistic expectations about time/effort.
It's not much more of a job. You already have the majority of the disassembly completely if you are at the upper manifold gaskets. You'd have to drain the coolant and remove the bolts securing the lower manifold to the heads to remove. Be careful not to let ANYTHING drop down those intake ports. Any small nut or bolt that falls down there could prove to be a MAJOR headache.
72CC428
08-31-2016 09:03 AM
guitar_199
1997 - 2003 F150
09-07-2010 06:03 PM
Thomsen
03-25-2004 07:31 PM
