Stupid C4 question
Stupid C4 question
I recently decided it was time to seek out another C4 transmission for my 67. While I have some mechanical ability, I was going to source a used C4 transmission and have someone else install it (bad back here). I went and took a look at a tranny early today. The seller claims it was rebuilt last year. I am not familiar with how C4s work. During the inspection, I tried to turn the torque converter and it was very stiff. The seller claims he installed new pump gears and the converter was new. I removed the TC and I turned the smaller input shaft and it did turn with some effort, again stiff. While turning the input shaft, the seller seemed perplexed that the output shaft did not turn. I was under the impression that the input shaft turning SHOULDN'T move the output shaft when it was out of the car. I then turned the output shaft and THAT DID turn the input shaft. Am I wrong? Please correct me if I am, thanks.
I'd probably like to know that too since I have a '67 car that I'll want to put one in while it's getting a new motor.
Some of the guys on the Fordbarn site know about transmissions as it's a frequent subject on there. Might check there if you don't get response on here. It could be since you posted at 10:40 that everyone's gone to bed and you'll have some answers soon.
When it's out of the car there is no direct connection from the input shaft to the output shaft. Sometimes they will turn each other just from drag. If you hold one of the shafts you should still be able to turn the other one.
The only way the shafts connect is when bands and/or clutches are applied, and that takes hydraulic pressure.
on
What would make me nervous is that you say the seller worked on the tranny but doesn't seem to know that much about how an auto tranny works. Or did he have it done professionally? I wouldn't be thrilled about buying a used automatic from a guy who doesn't know much about them and just slapped some new parts in there...
Mark, thanks so much! That is what I thought but having someone question it made me question it. lol One other question - The seller claims he changed the pump gears and put on a new remaned TC and that is why the torque converter is so hard to rotate when fully seated. Does that make sense?
The seller stated that he had it rebuilt by a local shop but never reinstalled it. He purchased the TC after the rebuild so I know I never had the shop mate both of them up. He is asking $50 for the tranny and tc. I feel like if its something simple it is worth the asking price but if it needs a full rebuild again then I will rebuild the one I have.
Mark, as for the pump clearance, does the larger thrust washer set that and the smaller washer set the input shaft end play? Or is it the other way around?
I totally agree. It would also be worth rebuilding, I am just trying to figure out if something small was rebuilt incorrectly or if the whole thing should be rebuilt.
There is no way to set pump clearance on a C4. The selective washers only set up end play.
may have some C4 knowledge here, will ask while I got a chance…
I understand that only 1 co. makes parts to make this tranny having 'engine braking' in first gear - most just have it in 2nd & 3rd. (wanna use it in a workin bronk that skids logs up 2 the neighbor's band saw mill). I think the co's name is "Performance" or something like that - R U guys familiar or can U assist in sourcing prts? Tranny is from a V8 and will B behind a torquie six (less HP/similar tq).
