6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Axe The Cat, or Let It Live On? (converter, that is)
Old 02-15-2016, 07:47 PM
turbinefix's Avatar
turbinefix
turbinefix is offline
I'm about the do a DPF delete and was wondering if it would further help to remove the catalytic converter as well, versus leaving it on. I'm not sure how much back pressure it creates, etc. Any thoughts? Thx
Old 02-15-2016, 09:16 PM
brandonrr's Avatar
brandonrr
brandonrr is offline
There's 2 different mindsets when it comes to deleting the cat.
Since you are deleting, you could just get a turboback exhaust without the cat. There isn't much point in leaving it on if you aren't emmisions compliant anyway. It should run slightly lower EGTs if running hot tuning than if you left it on.
On the other hand, leaving it on will cut back some of the exhaust noise, mainly the "woosh" noise from the turbo. It doesn't create a lot of backpressure and shouldn't be a problem unless it clogs up. Unless you plan to run crazy tuning, it wouldn't hurt to leave it on. Not running a cat will also increase exhaust odor a little bit.
Old 02-16-2016, 10:04 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
depends on the state you live in and if they currently or plan to do emmissions testing...look into that.
Old 02-16-2016, 03:24 PM
turbinefix's Avatar
turbinefix
No emissions test in FL. Looks like it'd be easier to take it off with the DPF because they are connected. Thx 4 the input!
Old 02-16-2016, 04:17 PM
genotac-f250's Avatar
genotac-f250
genotac-f250 is offline
I went straight pipe from the turbo back. Not going back!
spiritwild
Bronco II
08-01-2015 06:48 AM
jimbn
1999 to 2016 Super Duty
04-01-2006 02:00 AM
TLindquist
08-12-2005 05:44 PM
Craze
17
06-11-2004 09:35 AM
2000ranger
1983 - 2012 Ranger & B-Series
06-15-2003 01:15 AM
Quick Reply: Axe The Cat, or Let It Live On? (converter, that is)
