gray smoke at ilde
gray smoke at ilde
ok guys i just picked up a 1986 ford f 350 w 6.9 with a sidewinder turbo set up got a new injection pump the glow plugs seems to be working really hard to start the fuel tank selctor valve has been bypassed a hose going from tank to mechical fuel pump is a new hose once you get it started it runs really bad like a mis fire then alot of gray smoke comes out of tail pipe i need some ideas to look for thank u for reading
Also, at extreme retardation levels, one slightly weaker injector can easily become a miss. And our injectors tend to be all over the place with regard to pop pressure, enough to matter when at these extremes. So you can easily have a horribly smokey engine that *also* has a miss due to just timing.
TNDIESEL88
10-13-2016 07:58 PM
christofalex
09-14-2016 09:12 PM
BIG ATS
03-04-2016 06:12 PM
89IHDiesel
08-26-2014 04:46 PM
guisepi
26
12-15-2013 12:27 AM
