My Blue F100 HAS A SHORT, IM GOING NUTS!
I would like to thank everyone beforehand. Here is where i stand, I have old blue (73 F100 302 V8) parked for a while, when i would attempt to start it, the starter would get stuck (it would keep cranking). I jumped the gun and replaced the starter and solenoid. (being careless, when i was uninstalling the solenoid, my wrench touched the horn relay and caused a spark and blew a fuse) When i finished installing the starter, solenoid, and fuse, i proceeded in connecting the battery cables but as soon as the battery cable touched the terminal it sparks and the truck starts cranking nonstop w/o keys. What can i do to fix this, i made sure to install all wires in its appropriate places.
I'll see if i can upload any photos this coming days but for now please advise!!!!
on
Check if there is voltage on the 'S' terminal (Starter Relay/Solenoid). If there is volts with the ignition switch NOT in start position, then it's most likely the Switch.
Alternatively, pull the 'S' terminal to see if it continues to crank... Might be a brand new Starter Relay/Solenoid Dud!
jerryst
01-22-2016 08:12 PM
forestgreen
05-04-2015 01:16 PM
rustranger07
12-06-2011 11:59 AM
Chromepro
15
08-08-2005 06:15 PM
F-250_1970_CampSpl
07-28-2004 06:07 PM
