cam sensor wiring
cam sensor wiring
I was hoping maybee someone could tell me what the part is that the cam sensor wiring goes too, I see the harness branch off to a part on the lower front of the block (kinda looks like a temp sensor) on drivers side. I appreciate any advice. Just threw a 1309 code and would like to do some homework. Thanks all
dtc p1309
I was hoping maybee someone could tell me w, hat the part is that the cam sensor wiring goes too, I see the harness branch off to a part on the lower front of the block (kinda looks like a temp sensor) on drivers side. I appreciate any advice. Just threw a 1309 code and would like to do some homework. Thanks all
I found this; P1309 FORD Misfire Detection Monitor Not enabled | AutoCodes
What are you working on? Sounds like the cam sensor has to be setup and positioned properly or it will give that code.
Btw the truck runs great,two weeks ago I experianced a crank but no start situation for a couple days and got stranded, it eventually started and has been running since. This is why im here now. Thanks so much.
I was told by AZ that the cam sensor was mounted right on the top of the synchronizer and its not. The wiring I was wondering about literally does go to a temp sensor.........man I feel like a jack ***, sorry for wasting everyone's time though.
Don't beat yourself up too much---that's why we're here!
Honestly though I'm sure most of us have also made similar mistakes. One of my all time favorite self-created sayings is: we learn more from our mistakes than our successes.......... After all the biggest part of life is learning what NOT to do.
Sent from my SCH-I535 using IB AutoGroup
