How do I remove it? This **** doesn't have a square notch, just a small hole. I'very tried a pick and small Allen key but I've had no luck. Anyone have any ideas?
Don't have an "idea"... knowledge!
There is a springy tang through which the shaft passes through. Position a pick behind the **** and press it against the ****. Hopefully it depresses the springy tang. Use a mirror to take a look at what I mean and you'll "get it".
Well I just got it off seems there is set screw in it. I just pushed an Allen key in the hole kinda hard and turned and it back off enough to get it off. Maybe someone put a different style **** on.
Like HIO said, look at the picture, see the little notch? There's a small tang in it. Get a seal pic, bent paper clip or something similar between the tang and dash and pull towards you. This will release the ****.
sheesh. i keep accidentally pulling that **** off when i go to turn on my headlights and miss and grab the wrong **** >.> my husband laughed... till he did it himself. XD
Yeah it's not oem anymore and it was driving me crazy. I searched and all the instructions were to press the metal tab but I knew it looked different. Just happy to get it off and on it one piece.
i knew about Ford style ***** and how to remove them properly from owning an '85 ranger when i was young... doesn't stop me from grabbing the wrong one on accident at night when i can't see what i'm doing. oops >.>
Any idea what size Allen key? Mine doesn't have the notch so I'm assuming there's a set screw too. Can't really see anything tho lol
You know I don't remember. I think it was the second smallest metric one I had in one of those cheapo sets. I pushed it in there pretty damn hard and kept turning. Good luck.
Thanks for the quick reply, well after some fiddling to no avail, I took some pics, it's got these slots on both ends but one looks to be partially sealed by the factory molding process. Any thoughts?
