Blower motor works, then doesn't
I have a 2008 E350. i've already replaced the blower motor resistor, and the blower motor itself. The blower motor switch works then it doesn't. If I take out the 50 amp fuse and put it back in the fan switch works. After a couple of times, it then won't work unless repeat the fuse removal etc.
Anybody know why this is happening? I could just replace the switch and see what happens, but figured I see of anybody here knows why this is happening.
You could have an issue with the switch and/or its connector----those are both known points of failure. Mine have almost melted, when accessed for inspection they're greatly deformed from heat caused by a relatively large amp draw over time.
Since you've changed the other parts its time to look at the last remaining parts that could be causing your intermittent operation.
HTH
HTH
Edward Heath
09-18-2017 08:39 AM
j4wall
05-01-2015 06:38 AM
7636074460
07-14-2012 09:09 AM
apollo95
1983 - 2012 Ranger & B-Series
10-10-2006 12:31 PM
