Here you go? I want to see this short bus body on this F350 frame, sounds cool. Like I said, I will ck my parts rig this weekend. If you can ID the part you by # that will make it faster and easier.
I have a 1973 F-350 missing the hardware that connect the brake booster rod to brake pedal.
Is yours just a straight through rod or did it have the style with the linkage ? There are many different setups through the years and any given truck one came out of. If your missing everything it could be hard to say for sure just what setup it had.
