Data mileage collecting before the ZF-Swap...
Old 02-05-2016, 08:22 AM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
The AOD is kind of an odd duck. It doesn't use a lockup clutch like modern stuff, but in factory form has an extra input shaft that splines into a hub that is welded to the converter case. 1st and 2nd it uses the converter normally, third it does a 60/40 split between direct drive and the converter, when it goes into 4th it goes to 100% direct drive. So you will never feel the extra "shift" of the torque locking like a newer vehicle.
However, for performance applications it is common to delete the direct drive portion of the torque and switch to a one piece input shaft, eliminating lockup in favour of performance and durability.
Ford did put the AOD behind 351w's in cars, I had one many years ago, but while it appeared early on behind the 302 in trucks, it was late to the game with the 300 and of course never behind the W. I'm not sure about the AODE, but I know by the time the 4R70W rolled around they had decided that an AOD based trans behind the 300 was still a bad idea and it was E4OD only.
  #32
Old 02-05-2016, 08:43 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Interesting. But, how did they do a 60/40 split?
  #33
Old 02-05-2016, 12:07 PM
82F100SWB's Avatar
82F100SWB
This is the best explanation I can find:
Educated Question On Aod And 60/40 Torque Split - Engine/Driveline Tech Talk - STLMustangs Forums
It's a simple system, but the explanation is not.
  #34
Old 02-05-2016, 12:29 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I understood every word of that, when taken individually. But, when strung together it was over my head. However, I think I got the gist. Thanks!
  #35
Old 02-05-2016, 12:56 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
Which would effectively give you a C6.
I've had both in one truck and didn't see any difference in power consumption (or mileage if not using OD), so it would be interesting to know what advantage a '3-speed' AOD has over a C6.
  #36
Old 02-05-2016, 01:45 PM
82F100SWB's Avatar
82F100SWB
The non lockup setups keep o/d somehow. Never really looked into it as I've only ever owned one... Lol
  #37
Old 02-05-2016, 07:42 PM
81ChopTop's Avatar
81ChopTop
81ChopTop is offline
If you really wanted to, you can buy a bell housing for the AODs to adapt to a FE or 385 series engines too. If built correctly, they will hold the power. You have to mill off the factory bell and the new one bolts on by the pump bolts.
I really don't exactly know how everything works even though I've rebuilt several with good results, but there's a lot of pieces parts in 'em. Much more than a C-6.
82F100SWB - I can follow most of that link, but I'm too tired to make complete sense of it right now. I get the basic understanding of it.
Sorry for the major derail reamer.
  #38
Old 02-05-2016, 09:30 PM
82F100SWB's Avatar
82F100SWB
Lentech builds one heck of an AOD, but I'll still take a 4 or 5 speed any day of the week. I'm slowly accepting the reality that my best option for wheeling rig is a C6 as much as I don't like it...
  #39
Old 02-06-2016, 07:33 AM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
I had an AOD converted to non-lockup and manual valve body in my Bronco for a while. It definitely had 4 gears.
COO
2017+ Super Duty
10-01-2018 03:26 PM
Arctic Fox
6.2L V8
39
08-06-2017 03:38 PM
jgavac
29
10-10-2013 07:56 PM
true blue
15
08-17-2006 09:32 AM
Quick Reply: Data mileage collecting before the ZF-Swap...
