1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Addition of OEM Rear Overload Springs
Old 01-31-2016, 10:47 AM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
I know I should either get the aftermarket 3500 lb helwig helpers or air bags for towing just have not decided on which way to go .
Old 01-31-2016, 10:58 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Or another choice.......
Find your nearest spring shop. Most major cities have one or two. Tell them what you want in the way of rear suspension performance, then ask them what they would do and how much it would cost. I think you'll find that solution cost effective when compared to OEM parts.
Old 01-31-2016, 11:24 AM
RainDesert's Avatar
RainDesert
RainDesert is offline
Originally Posted by 406
I do kindof like the idea of airbags though...
Me too, and it should be easier to install. I have had air bags before and they have worked great. It gives you the ability to handle a heavier load without the sag. I feel the heavier toyhaulers I had towed better when I had air bags and prevented the suspension from being loaded down.
Old 01-31-2016, 02:15 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
Originally Posted by fordman19762003
I'd get an aftermarket overload spring, the factory one is too soft and really doesn't help all that much anyway.
I completely disagree with that. I carry a 2300# concrete block in the winter for ballast and I modified my overloads to engage right away and the truck raised back up 2". I would say those springs work pretty damn good
Old 02-01-2016, 09:12 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
Originally Posted by Hotrod70d
Why not just run the helwig aftermarket helper springs , ya it's not factory , work just as good or go with the airbag setup just a thought.
yes...add the overload overleaf kit...comes with all hardware and you do not have to remove anything thats there now. 20 to 30 minutes per side and your done.
F350super
2017+ Super Duty
29
04-16-2021 08:06 PM
srg726
07-31-2019 03:53 PM
cabloom300
05-05-2017 10:11 AM
sevensecondsuv
02-25-2017 11:26 PM
SuperDuty93
11-23-2012 05:35 AM
Quick Reply: Addition of OEM Rear Overload Springs
