SD Axle Swap shopping list
I'm giving serious thought to doing the Super Duty axle swap on my 97 F350 4X4. I don't really have the option of buying a wrecked roller, so I need a good shopping list for when I head out to a wrecking yard.
From what I can tell, I need to be looking at '05 to '08, or will any '05 and up work?
Thanks in advance.
Thanks in advance.
remember that the distance between the springs on SD's are different than the OBS.
The SD front is a Dana50 solid also.
Not much difference between it and a 60 but a few small things.
The 3.73 gears are pretty neat and the gen 3 stearling has a 3 spider carrier as opposed to a 2. as well as a 10.5 ring gear instead of a 10.25.
The rest of the axle is identical except for the pinion, which is actually smaller than a gen 2.
So, in order to mount SD axles on an OBS, you have to use a portapower to spread the springs out to line them up. (it could be suck it in, i forget if its wider or narrower, but its like a 1 to 2 inch difference)
And... thats not good for the suspension.
Its not designed to work with that load.
Ive only ever seen a PSD bronco have that conversion though.
The rear axle is still different.
Have fun mounting those buckets for the coils.
It sure will ride nicer though.
I'd rather have the leafs and an RSK.
I've been doing quite a bit of research, and it does seem to be RELATIVELY easy, I was just hoping to find 'Hey, don't forget to get ___ of the donor." I haven't come across that yet.
Well this is slightly off topic, but I subscribed to this one, because I HATE my open rear diff. My truck gets stuck looking at grass, not even mud. I am hoping to find a cost effective way to get rid of the one wheel wonder action. Long shot, but do you guys think running 80 psi in the tires is affecting me. I have never seen any truck get stuck like this one.
The easiest thing to do would be to air down and see.... I am sure tread pattern means the world, keep in mind a lot of off roaders and jeep guys run 6-15 psi in their tires when off roading...but you don't want to do this all the time!
