1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
SNAPPED LEAF SPRING
Old 01-25-2016, 10:13 PM
paradisemedic's Avatar
paradisemedic
paradisemedic is offline
SNAPPED LEAF SPRING
I just realized my driver's side front leaf spring on my 2002 F250 has snapped. I checked the weight sticker on my truck and it weighs 5200lbs in the front. My question is the heaviest springs I found only support 2630lbs a piece, so being a 7.3 is 5200lbs a correct weight for the front of this truck? also why would Ford make springs that support only 60lbs more than the front weight? Hell I weight more than 60lbs.... Did I snap the damn thing just by climbing into the cab?!?!
Old 01-26-2016, 01:43 AM
02F250V10's Avatar
02F250V10
02F250V10 is offline
5200 pounds is what the front axle is rated to carry not what it actually weighs. Those springs should work just fine as they are actually rated for more weight than the front axle is.
Old 01-26-2016, 01:55 AM
nojoke327's Avatar
nojoke327
nojoke327 is offline
You can get heavier springs all the way up to 3000 each.
Old 01-26-2016, 02:41 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
dont forget the springs only support weight thats above them, so that axles wheel and tires weight dont count they are considered unsprung weight.
Old 01-26-2016, 04:23 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
The x springs are plow rated for 6000 lbs. They raise the front like 1.5 inches..
Old 01-26-2016, 06:06 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
Learn what you are investigating.
springs only HOLD the axles to the truck.. the springs support body/engine/load...
and you are talking about springs that are 13 years OLD. not new springs....
even semi-tractor trailers break spring....
anything that bends/moves will fail at some point... that is LIFE. they do NOT heal like a cut on your arm ,
Old 01-26-2016, 11:42 AM
paradisemedic
ahhhhhhhh thanks for the help guys, I knew it was a matter of time before the spring snapped. I was just a little uneducated as to the dynamic workings of the springs themselves. Thanks for clearing it up!!
4dfan
1983 - 2012 Ranger & B-Series
06-16-2011 09:13 PM
greenpus
12-14-2010 09:14 AM
idahofordguy
09-06-2008 10:32 PM
muscletruck7379
05-15-2004 11:51 PM
ront
03-28-2004 08:34 AM
Quick Reply: SNAPPED LEAF SPRING
