Needing Heat/AC controller diagram.
I have searched through and couldn't find, sorry if I overlooked, but I need the wiring/vac hose/ cable diagrams for the under dash heat and ac if anyone has them. My heat will only blow on the defroster and I'm finding all kinds of things the PO has done so I want to make sure all is correct. Thanks, Mike
1973/79 F100/350 & 1978/79 Bronco: THREE different types of A/C:
1) Upper & upper center pics: Factory installed integral A/C is combined with the heater. The A/C controls are located in the same panel as the heater controls.
2) Lower center pic: Deluxe dealer installed A/C is combined with the heater.
The A/C controls are located in the HUGE dash bezel that sweeps across the entire right side of the dash, covering up the glove box.
There's a 'hang-on' glove box bolted to the bottom of the dash.
3) Lower pic: Economy dealer installed A/C is not combined with the heater. The A/C controls are located in a panel that also contains two A/C registers.
This panel fits into the dash to the right of the glove box.
justtin00j
05-31-2011 01:35 PM
78sharpshooter
07-09-2007 08:50 PM
