Sport Trac Compression?
I got my head gaskets done on my 2007 Explorer Sport Trac 4.0 SOHC in December. When I got my truck back the PCM was blown so I replaced that. Now the truck runs real rough. No codes are coming up. I pulled each plug wire from the coil block and it seem like cylinder 5 and 6 are dead. I am getting spark on all. The plugs on all cylinders look white (lean ???). I checked the compression on 5 and 6 and its low. Does this mean bad head or piston rings?
Could it be injectors or something else? The long term fuel trim is 20.
Also, if the PCM was blown, did you figure out why it had gone bad? Moisture, bad ground, voltage spike? If there was a problem with voltage or ground to the old PCM causing it to fail, it might be affecting the new one until it finally gives up the ghost. The computers in modern cars are pretty robust, but they are still razor thin contacts and circuitry mounted to a fiberglass board.
Oh, yikes...did you just replace the head gaskets and not have the heads tested? Gaskets rarely fail unless through corrosion, and even then, the corrosion that affected the gasket will likely affect the head as well. My Guess is that the original failure was between 5 and 6? If that's the case, then that head needs to come back off and get resurfaced/magnafluxed/checked for cracks.
slimfitz
01-31-2013 11:12 AM
