Do I need to drain the coolant when changing a thermostat.
Old 01-23-2016, 03:33 PM
imsorope's Avatar
imsorope
imsorope is offline
I need to change my thermostat in my 1992 F150 5.8L V8. Do i need to drain the coolant? Completely? Just to a certain level? Not at all?
thanks,
Imsorope
Old 01-23-2016, 03:37 PM
bashby's Avatar
bashby
bashby is offline
Dont have to. You're gonna spill some even if you do drain it.
Old 01-23-2016, 03:40 PM
chrismd188's Avatar
chrismd188
chrismd188 is offline
I usually open the petcock on the radiator and drain some out,you'll probably spill some unless the thermostat is stuck open
Old 01-23-2016, 03:41 PM
Phy's Avatar
Phy
Phy is offline
Well, think about it. You need to drain it to a level lower than the thermostat housing.
Old 01-23-2016, 04:21 PM
danr1's Avatar
danr1
danr1 is offline
Yea I drain it down a ways, Anti freeze is kinda pricey and I don't want it on the ground.
The water I drink and bath in comes from under the yard!
I drain it to a clean bucket and keep it clean, when done with repairs I filter it through a couple of clean rags and putting it back in the radiator where it came from.
As long as coolant tests "good" is clean and "green" I do not replace it.
Old 01-23-2016, 04:59 PM
animator's Avatar
animator
animator is offline
Definitely helps to drain it. I recently replaced mine (different engine though), and it is helpful to drain it. You'll still spill a little, but less than if not draining it at all.
And of course, don't forget to bleed the system once complete.
Old 01-23-2016, 05:00 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Exactly as danr1 mentioned.
Coolant is pricey and I grab several jugs whenever I find it on sale.
And I also use clean rags to strain the recovered amount too.
Old 01-23-2016, 05:07 PM
kaduh's Avatar
kaduh
kaduh is offline
I've always used a coffee filter. They fit perfectly into my funnel.
MC5C
12-12-2012 02:31 PM
brickie
03-25-2012 06:28 PM
nedshead
1997 - 2003 F150
02-10-2007 06:08 PM
DouginTahoe
04-14-2005 07:38 PM
mightypizu
10-15-2004 04:04 PM
Quick Reply: Do I need to drain the coolant when changing a thermostat.
