front hitch, what to do with fog lights??
I was looking at installing a front hitch on the 250SD and when watching the install video at etrailer it shows taking the fog light out and taping the wires up.
I guess some of the supports of the hitch block the space for the fog lights.
SO is this any way to remount them or is there some other type of fog light you can use the existing wire hooks for.??
Want the hitch on front for moving trailer if needed and for 12,000 lbs winch, bike rack on front etc.
Install a different style of front hitch by Curt, that doesn't require the removal of your fog lights at all.
The different style bolts down low where the Blocker Beam resides, not up high behind the foglights (where it also blocks air flow to the power steering and transmission coolers).
I'd have to charge more than you can buy a rolling one for. It is very stout however if I did it again I would try and lighten up the steel a bit, it is fairly heavy. It does knock down though and hangs nicely on the wall in two pieces.
I considered one of the cheaper folding ones but the reviews are not real great
