Front spring shackels
Old 01-21-2016, 12:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Originally Posted by harley4jcs
You don't need to swap springs What you gona do Swap them again this summer for the beach trips ??? Your springs will handle the plow just fine. You just want to level your truck, BIG difference.
He doesn't spec what bumpers he has but if it is a typical fabricated style bumper that is what, maybe 500 pounds, 8' plow runs 800 pounds , so I would argue 1200 additional pounds on the nose of the Ex warrants a swap to different spring rates.
Put it this way, a 7.3 diesel motor weighs about 1200 pounds. I think we can all agree the addition of a 7.3 engine on your grill is going to take more then some spacers to achieve the ride quality you expect.
Old 01-21-2016, 02:01 PM
ithaca1230's Avatar
ithaca1230
ithaca1230 is offline
I did consider removing the extra leafs from the B rear springs but they work great the way they are now. The Bumpers Front and rear are Roadrhino very similar to road armor bumbers. With the winch I say they are under 300 lb. Two guys can pick it up. All the comments really help me figure out what I'm gonna do.
Old 01-21-2016, 02:32 PM
harley4jcs's Avatar
harley4jcs
harley4jcs is offline
Originally Posted by pirate4x4_camo
That's cool, they are not need .... Until they are needed
Well said.
PS: After I thought about it, I was not 100% truthful.
I run bump stops on my shocks & love them.
Old 01-21-2016, 05:14 PM
pirate4x4_camo
300 with the winch is probably close to accurate.
Old 01-22-2016, 07:14 AM
ithaca1230's Avatar
ithaca1230
With the current set up the truck does not bottom out on the bump stop. I have not noticed it bottoming out with the plow attached. It still has room between the axle and stop with the plow attached. I usually have 600-700lbs salt in the back as ballast.
Old 01-28-2016, 10:18 AM
brycez28's Avatar
brycez28
brycez28 is offline
How about firestone air bags? I don't have a plow on my Ex, but it came with air bags. Each bag has its own inflation valve, I get a couple inches of lift with it at 20psi.
Old 01-28-2016, 10:46 AM
holeshotwalt's Avatar
holeshotwalt
holeshotwalt is offline
I would just install a 2" drop bracket kit. That'll give you the height without killing the ride. Cary at CT Performance (one of the originators of the V/modified B idea) has the drop bracket as part of the original 'kit'. It matches the front height to the modded B springs.
You can decide to leave or remove the 3rd leaf afterwards.
Old 01-28-2016, 02:49 PM
ithaca1230's Avatar
ithaca1230
Was gonna call them next week.
Old 01-28-2016, 03:00 PM
holeshotwalt
With his years working on Excursion suspensions, he is The Man; seen and heard it all I believe. He'll get you squared away. Tell him ya heard about him here!
Old 02-11-2016, 01:12 PM
wrxin's Avatar
wrxin
wrxin is offline
Has anyone found just the front drop brackets? I have "lift shackles" already but I'm looking around for the drop brackets.
ithaca, did you have any success? I bought lift shackles off ebay a few years ago and they worked great. They say something like 2" lift but that doesn't mean they are 2" long, they are much longer than the factory shackles. You'll need longer swaybar endlinks too if you don't have them already.
Old 02-11-2016, 02:08 PM
holeshotwalt
Call Cary Home
at CT Performance!
Old 02-11-2016, 04:13 PM
holeshotwalt
These guys have great stuff too:Individual Components and Upgrades
  #28
Old 02-12-2016, 10:18 AM
wrxin's Avatar
wrxin
wrxin is offline
Originally Posted by holeshotwalt
Call Cary Home
at CT Performance!
Thanks for the tip. I had a very confusing conversation with him, part of it was my fault, but they don't offer just the hangers.
He said he'd never heard of anyone using lift shackles.
  #29
Old 02-12-2016, 10:20 AM
wrxin's Avatar
wrxin
wrxin is offline
Thanks, I stumbled across them yesterday. Among other things, they have some pretty cool lift blocks.
For some reason, it's very hard to find just the drop hangers. People sell shackles and hangers but not just hangers. Might be time to break out the welder...
brian1080
07-05-2014 11:59 PM
PatsPOS
04-07-2013 08:00 PM
cowboyty
11-10-2006 06:11 AM
mtgrzlyman
Offroad & 4x4
02-20-2006 02:08 PM
Quick Reply: Front spring shackels
