Shift indicator light led
I do not think you get it, but their web site or a tech line call should answer your question. Instrument cluster light bulb/LED swap is not in the same area as the steering column gear selector light.
Yes it is just a bulb that you should be able to swap for an LED?? You have to take some of the column apart to get to it though.
It is not part of the gauge cluster kit. This is directly off their site.
What's Included in an LED Conversion Kit?
Our LED gauge lighting conversion kits cover all of the bulbs in the main gauge cluster of your vehicle.*
Our kits include LED bulbs for the following:
- Gauge Cluster Illumination Bulbs (the bulbs that light the gauges)
- Turn Signal Indicator Bulbs
- Warning Indicator Lamp Bulbs
- High Beam Indicator Bulb
The info on the shift light is here
1973-79 Ford Truck & 78-79 Bronco
BigRed1967
10-01-2023 11:00 AM
