Looking for Trailer Charge Relay - 2016 F250
from Ford website for 2016 F350 manual
Relay #90
http://www.fordservicecontent.com/Fo...G1628862&div=f
Relay #90
On another post (which I can't find again) a member commented that Ford now controls the Trailer charge line with an intelligent battery monitor system. Basically, if it doesn't see a load (battery that needs charging) on the line it doesn't power the line. They also pointed out that this line isn't fed power until you crank the truck and put your foot on the brake (which since you have to put your foot on the break to crank anyway I wonder if he meant you have to put your foot on it a second time).
But the other thing I noticed is that the Orange wire (battery charge line) is TINY. It looks like a 18 gauge wire. What's up with that? I'm used to running 10 or 12 gauge wires from a battery relay to the trailer connector.
Thanks Steve! So the brake is the key! I'll try that in a few minutes. I must have missed that in the manual somewhere. Thanks so much!!
As near as I can tell and for reasons I don't clearly understand, the charge lead does not become active until the truck is sure a trailer is connected. That assurance apparently comes from the brake controller finding the trailer when the brake pedal is pushed or, I am assuming the controller is activated manually. Once that happens, the charge lead comes online.
Steve
Steve
