Steering wheel off center
There are some turnbuckles, they call them adjusting sleeves, by the tie rod ends. Obviously you have to shorten one tie rod and lengthen the other. If you do this yourself, make sure the one you lengthen has enough threads still holding to be safe.
If you do this yourself, you can count the turns you turn each sleeve but I'm not sure your toe adjustment will be right on.
AZ48
01-30-2014 11:24 PM
traderssd
1978 - 1996 Big Bronco
01-16-2013 01:06 PM
traderssd
01-16-2013 09:44 AM
carprojects
1999 to 2016 Super Duty
02-01-2011 09:30 AM
