01 Started Blowing Blue Smoke
01 7.3 247k.
Yesterday went to get on the freeway I looked back and saw a cloud of what looked like blue smoke. I'm in northern Utah and it's cold but the truck runs fine, I haven't noticed any change in performance. Turbo still builds boost. I pulled the fuel filter cap last night to check fuel color and it was clean. I do have the CCV mod done. I also pulled to IC Pipe off the turbo and there was a little oil in there but not much, should there be any at all with the CCV mod?
Just looking for some ideas on where to start. Thanks!
01 7.3 247k.
Below are a few of the more reputable shops to get a rebuild kit from. I bought the $59.99 kit with 360 bearing from SP Turboost and it was a well put together kit.
Ford Powerstroke 7.3 Liter ? SP Turboost Company, LLC
Barder Turbo with 360 bearing
7.3L TP38 / GTP38 Rebuild Kit with 360 Thrust Upgrade | BARDER TURBO SERVICE
RiffRaff stock/OEM kit
Garrett GTP38 Journal Bearing Rebuild Kit - Riffraff Diesel Performance
If your in northern Utah you just might want to get the rebuild kit for the pedestal. By Keeping the ebpv operational your truck will warm up faster in the winter time. I deleted mine because I live in Florida. But if you do decide to delete it then make sure you get the 470 ohm resister to plug in the end of the connector and the adapter where the ebpv would be.
