Truck howls under throttle
Old 01-12-2016, 08:08 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Yeah I've been using an old tarp I found in a shed... Problem was I left it out in the rain lol oops... Thanks for the protip though!
So. I have a ls 10.25 sterling with 3.55. Now I have to figure out what bearing is bad... I think I'm going to just bring it in to a shop and bite the bullet.
  #32
Old 01-12-2016, 09:46 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
There should've been more oil coming out that hub when you popped that axle out.
  #33
Old 01-12-2016, 10:16 AM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
He said it was super low on oil...
  #34
Old 01-12-2016, 03:40 PM
Jarrett Campbell
I had already pulled the diff cover and drained it.
So I got a quote for $1300 for diff bearings and wheel bearings and axle seals... Yowzers
  #35
Old 01-12-2016, 04:35 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Ouch.......
  #36
Old 01-12-2016, 06:28 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
That seems steep
  #37
Old 01-12-2016, 08:38 PM
Jarrett Campbell
I know right? T4 s366 or differential...Tough choice....
Can I drive in front wheel drive for a while? Lol
  #38
Old 01-20-2016, 11:01 AM
Jarrett Campbell
Necessary to replace?
  #39
Old 01-20-2016, 04:27 PM
427 fordman
Really hard to tell wear on a ring gear with just a picture, but with that what looks to be rust along with at least some noticeable wear, I'd replace. Especially if I was diving in to repair a bearing.
edit: Did you find a bad bearing? I don't remember. If not if that ring gear is worn bad enough it will cause your noise.
  #40
Old 01-20-2016, 04:40 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Unless there is some extreme wear on the pinion I don't see enough wear on the ring gear to cause noise.
  #41
Old 01-20-2016, 04:50 PM
Jarrett Campbell
It would be more of a while we're on there kind of thing I think. Idk if it's worth the extra $430
  #42
Old 01-20-2016, 06:18 PM
CampSpringsJohn
Did they find any bearing problems?
  #43
Old 01-21-2016, 07:59 AM
Jarrett Campbell
Yeah they said they found worn bearing coatings and some places where the cups were worn. He said that the bearings were where most of the howling was probably coming from and any noise caused by the corrosion would have been on deceleration.
1994Toyota
08-18-2018 09:59 PM
Pockets52
6.4L Power Stroke Diesel
03-29-2013 08:25 PM
bmoran4
09-28-2010 12:34 PM
dale88
07-29-2008 09:39 PM
Quick Reply: Truck howls under throttle
