Fighting loss of spark
Old 01-03-2016, 07:08 PM
Anthony487's Avatar
Anthony487
Anthony487 is offline
My 1979 f150 with the 351m and c6 will be driving and suddenly shut off. Sometimes it'll just start up without me touching anything, other times I have to crank and crank then it starts. It does NOT stumble when it dies, It just stops firing, which is telling me it's electrical.
There is NO reoccurring pattern, it is random.
I have great grounds, already swapped out ignition module, brand new distributor a few months ago and all fuses good, also have a new coil and resistor as well.
I have read several forums about this but all were slightly different than my problem. Anyone have any idea before I start testing wires out in 2 degree weather?
Thanks guys
Old 01-03-2016, 07:58 PM
No704's Avatar
No704
No704 is offline
Maybe the ignition switch? How much crap ya got hanging off your key?
ken selvy's Avatar
ken selvy
ken selvy is offline
Try your ignition switch, mine died in the freeway and then fired and finally died .
Old 01-03-2016, 08:11 PM
Anthony487's Avatar
Anthony487
I will order an ignition switch. It looks like it's the original switch. Any other suggestions?
Old 01-03-2016, 09:08 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
On my old 78 I found 1 of the 2 wires to the coil was corroded about 1 or 2 inches back from horseshoe connector.Cut it out and soldered a new wire.On another car It would run fine and die it was the fuel pump going out.
Old 01-07-2016, 06:59 PM
Anthony487's Avatar
Anthony487
Well it wasn't an ignition switch, getting a new coil tomorrow
Old 01-08-2016, 05:03 PM
Anthony487's Avatar
Anthony487
Isn't the coil or resistor either. I girl I start checking wires
Old 01-08-2016, 05:37 PM
awfulaggravated's Avatar
awfulaggravated
awfulaggravated is offline
I seen that you replaced the module, ive actually bought one way back when from autozone and it was brand new and as useless as the old one,id really look into that module again
Old 01-09-2016, 11:19 PM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
They don't like it here but if you are pulling hair a good HEI will get you rolling again.. (I like mine)
Old 01-10-2016, 08:12 AM
scottscott's Avatar
scottscott
scottscott is online now
Replace the pickup coil in the distributor. Even though the distributor is "brand new" a few months ago.
Old 01-11-2016, 01:11 PM
Filthy Beast's Avatar
Filthy Beast
Filthy Beast is offline
Agree with "just 'cause it's new, it should work" but doesn't theory. Re-check the brain box - get a Motorcraft if you haven't already, recheck your pickup coil in the distributor as previously mentioned, and check the wires inside the distributor plate for connection/brittleness.
It really sounds like an intermittent ground, insulation rubbed off a hot wire and is shorting the system out, and/or a semi lose (+) connection. Solenoid ok and bolted to a good, clean ground?
Connections to the coil good and snug....not frayed or lose? Orange and purple wires resistance from distributor ohm out good? - between 400-700 ohms?
Old 01-12-2016, 07:11 PM
Anthony487's Avatar
Anthony487
Found the problem!
First, thank you for all the responses and I hope this will help people in the future.
I checked my pickup and I started tracing wires, then it just came to me. My coil was leaking, thus over heating. I'm guessing that backfed power to the icm which fried it. So I got a new coil and a new icm and it's been fine.
Old 01-13-2016, 09:53 AM
Filthy Beast
Glad to hear you're up and runnin'
Old 01-14-2016, 10:56 PM
OLDBLUEF250's Avatar
OLDBLUEF250
OLDBLUEF250 is offline
My truck is doing the exact same thing..
I will check my wires and brain box
Old 01-15-2016, 07:10 AM
MBDiagMan's Avatar
MBDiagMan
MBDiagMan is offline
When you replace the coil, make sure the semi circular looking connector that slides over the primary terminals is tight. I have seen the contacts lose their springiness and cause it to cut out like you describe or not start. That connector is a common and inexpensive repair part, so if it is loose at all, go ahead and splice in a new one. Hope this helps.
Quick Reply: Fighting loss of spark
