TPMS Adjustment?
And what's the difference? After reading several write ups, there wasn't a thing that said you couldn't arbitrarily set the tires at a lower pressure. Mine are all at 60-65 psig regardless of where they were before. As far as I'm concerned, the tool works on my '11 and that's what matters to me.
The instructions for the TP19 - they have to be downloaded from the 'net. Here's one set of instructions that is similar to the Ford version :How to Train Ford Tire Pressure Monitior Sensors TPMS | eBay
Hope your renovation goes well... Please post your results so that future readers will have a real answer. Keep in mind that the tpms triggers at some level below the OEM tire pressure - for example my 65psi front / rear setup will trigger the tpms at about 58 psi.
I've got a few out of town trips coming up starting next week, so I pulled out the owners manual looking for the training procedure as NoJoke stated. There is a TPMS reset procedure talked about on page 252, it starts out with the key cycling, pedal pushing yada yada. But then it introduces the TPMS reset tool half way through the procedure? How do we finish this procedure without the tool? Out researching the internet now.
Edit: Found this, not sure if it will work, says it does on F150's and i heard also on Focus cars: (TPMS starts about 4:20.)
A little conflicting with the manuals turn key, hit and release brake. Instead key on and hazards 6 times.
Some more reading material.... If you can't tell, im the type of person who hates having their dash lit up.
https://www.ford-trucks.com/forums/6...djusted-3.html
Looking for some input here as to what PSI i should run in my new Kumho KL-78's on my F250.
Currently I'm pissing off the TPMS (They call for 65 PSI) and I' currently running 50 PSI. My rims are the 20'' diameter (8'' wide) 8-spoke Lariat/King Ranch rims with 325/75/R20's on them. This size equates to a 35x12.6x20 americano.
They ride darn good where they are at, however with the salty roads here it looks as if the outer lugs don't have any "salt dust" on them like the center of the tires. This is true for the front and back. They are load range D as I rarely tow with this truck, if i do its a open car trailer with a 3K LB Fox on it.
The stock tires were 275/65/R20 which is a 34x10.8x20. (Originally had 37x12.5x20's when i bought it) I'm concerned to go much lower than 50 PSI.
I just got a Flashcal f5 1545 to use on a 2015 F250 FX4. It went from 245/75/17 to 35/12.5/20s and the air pressure went from 80 to 55 so of course the speedometer,odometer and TPMS was off. The flashcal seems to have worked on fixing all three. Dealership said they would do it for $140, but could not set tire diameter above 34". The flashcal was 199.00.
#29
