You're welcome. Did you weld the holes? I welded close to 100 on my highboy with a lincoln wire feed welder. Zap, wait, zap, burn through, weld up the new bigger hole, grind, weld....
Yes I didn't do the tailgate because I didn't think I could but I payed attention as my dad welded the big holes on the tailgate. I'm a better wire welder know but my main thing used to be stick welding. Can't wait to try tig welding.
I didn't run into any sensor issues on the k&n swap, know this won't work on a truck with a maf sensor because its in the intake. My truck has no sensors in the intake path. BTW went through you build thread nice truck
thanks but if you dont mind i am definitely gonna "steal" some of your ideas lol ethe only thing is that it seams impossible to find a performance air intake for our year 300 i6
Darn, I was hoping to use you as a Guinea pig. I'm wanting to try an rv cam and mild head work to mine when I pull the motor for a reseal next summer.
Lol, well I plan on keeping the stock computer for a while. I'm thinking about a isky or crower myself. I won't spend the money on a fancy computer until I need to.
No problem. But yeah there is almost nothing for our 300s unless we discover or engineer it ourself
