'73 F100 auto transmission popping out of gear
Hi all, I have a '73 F100, and its been popping out of gear when I drive it, but if I rev the motor a few times it will drop back into gear. I believe that it's only doing this in 1st, because it normally happens when the car comes to a stop. Any insight? Thanks in advance.
Like 75PKUP said, first check the fluid level, make sure it's at operating temp and the engine is idling.
If that's okay the next thing I would do is check the linkage adjustment. Check the linkage for wear, in particular the stud that connects the gear shift rod to the arm on the transmission, these tend to wear and the shifter could be in "D" but the transmission might only be "part way" in gear.
I don't think it's a modulator, that doesn't really sound like the symptoms of a bad modulator.
The way I adjust the linkage is I put the gearshift lever in neutral then I get up under the truck and loosen the nut on the stud on the trans. arm (the threaded part of the stud in the picture) and manually put the trans. in neutral and tighten the stud. The rod that goes from the steering column to the trans has a long slot in it to allow adjustment.
86-IDI
07-29-2014 06:38 PM
6.0 heavy loader
10-03-2007 11:16 PM
kjg26
17
08-24-2006 10:18 PM
