"The Donk" build thread
#76
#77
First thought: it's your truck, so do what you want.
That said, personally I can't see ever owning a Ford truck newer than '97. I had a brand new 2008 F-250 that I hated, then I bought a 2002 F-350 diesel that wasn't much better. But that's me. A lot of people still like newer Ford trucks, but I ain't one of them.
As for putting axles from a SuperDuty onto your F-150, I'm not sure I'd do that either. For what I would use an F-150 for I'd stay with the Dana 44 TTB. If I was going to do a solid axle swap I'd either go with a Dana 44, or Dana 60 from an older truck. The 44 would be lighter and would match the lug pattern on the rear axle (and still probably strong enough for anything I would do with it). And the 60 would be stronger without getting into the newer metric lug pattern and the unit bearings the newer Dana 50s and 60s had.
But again, it's your truck, so I'm not saying either are a bad choice, just that with the baggage I come with I'd make different ones!
#78
#79
#81
#82
#83
#84
the drop brackets are welded :/ prolly just take the beams out and use the ball joint press... so i have a bad outer wheel bearing on the passenger side. would that cause a "death wobble" kind of effect? cuz it has been kind of bad lately and finding that out i was wondering if that would cause it. other than that... its just the pivot bushing, and front shocks, which i don't think would cause the death wobble.
Apocalypse
12-19-2016 09:00 AM
Rogel Ford
06-09-2015 08:54 AM
lvin4jc
46
11-10-2011 11:30 AM
