4wd swap
Old 12-01-2015, 10:10 AM
kalebc2's Avatar
kalebc2
kalebc2 is offline
4wd swap
how hard would it be to swap my 1976 f250 2wd to 4wd. i have 4 speed trans.with 400 motor. Also thinking about putting a non intercooled cummins motor in it with 5 speed.
Old 12-01-2015, 10:20 AM
TheMonson's Avatar
TheMonson
TheMonson is offline
This guy just started the conversion on an F100.
https://www.ford-trucks.com/forums/1...on-thread.html
Old 12-01-2015, 11:29 AM
fordcrzymike's Avatar
fordcrzymike
fordcrzymike is offline
Generally it is not worth the hassle. You'd be WAY better off selling the truck and buying one that is already 4x4. The only reason to convert to 4x4 is if the truck has very strong sentimental value and money is less of a concern. Even then, it's easier to body swap.
Old 12-01-2015, 11:35 AM
Steven@nd's Avatar
Steven@nd
Steven@nd is offline
If you want the Cummins, etc. I would just buy the donor Dodge and swap the body onto it... then it's easy to find parts for the drive train in the future.
Old 12-01-2015, 12:46 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,357 Likes on 2,495 Posts
Not hard if you have lots of $, can weld like no other and can fabricate with your eyes closed.
So in all reality X2 on just what Fordcrzymike said. Get a doner 4x4 chassis with all the running gear and do a body swap in a weekend with a few friends, and be back on the road in no time.
Old 12-02-2015, 09:03 AM
kalebc2's Avatar
kalebc2
kalebc2 is offline
would a 76 f250 body fit on any 73-79 f250 truck?
Old 12-02-2015, 12:21 PM
77&79F250's Avatar
77&79F250
Yes for the most part, front clip and cab easy, but a 73-77 Highboy F250 truck has a narrower rear frame section. So depending on what application bed you have you either drill new holes in the bed or weld some frame brackets to use the original 76 HB bed holes. Does that make sense?
Old 06-16-2016, 09:48 PM
kalebc2's Avatar
kalebc2
kalebc2 is offline
Alright so I bought a 79 f250 4x4 with divorced transfer case. I'm going to do a body swap is there any modifications I would have to do? The body is a 76 single cab long bed same at the 79.
kalebc2's Avatar
kalebc2
kalebc2 is offline
Any info would help a lot
Old 06-16-2016, 10:42 PM
ShaneNP123's Avatar
ShaneNP123
ShaneNP123 is offline
If it's got a divorced transfer case it's not a 79 chassis. I'm willing to bet you have a highboy frame
Old 06-17-2016, 12:29 AM
fordcrzymike
As Shane already stated; no 79 would have a divorced transfercase. Other indications of a highboy would be the low front-most crossmember, ram assist steering, thick front leaf pack (I want to say seven leafs?), 4" narrower rear frame section, 2.5" wide rear leaf springs, in cab fuel tank, and obviously the divorced transfercase. If it is a highboy frame, mounting the bed should be the only tricky part. the rest should be fairly straight-forward. Personally I think Highboys are over-rated. I would rather have a "lowboy" with true power steering, and a married transfercase. Post some pictures of the truck and we will be able to tell you real quick where or not it's actually a 79 frame.
Old 07-01-2016, 03:43 PM
kalebc2's Avatar
kalebc2
kalebc2 is offline
Old 07-01-2016, 03:54 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
This is not a High Boy, it's either a 1978 or 1979 F250 Ranger Lariat. Lariat's were introduced in 1978.
High Boy: 1967/76 F250 4WD & 1977 F250 4WD before serial number Y20,001 (February 1977).
All High Boys have an in-cab fuel tank, divorced transfer case. 1973/77's use Power Assist P/S.
The High Boy's distance between the inner frame rails behind the cab is 33 1/2."
High Boy available engines: 1967: 240/300 I-6 & 352 2V / 1968/74: 240/300 I-6 & 360 2V / 1975/76: 300 I-6 & 360 2V / 1977: 300 I-6 & 351M/400.
Old 07-01-2016, 06:26 PM
kalebc2's Avatar
kalebc2
kalebc2 is offline
Would it be easier to swap everything under the Frame or do a body swap?
Old 07-04-2016, 12:07 AM
fordcrzymike
You can't just swap the running gear. For one, the 4x4s use a leaf spring front suspension while the 2wds are coils, so you'll have to fabricate all the hangers, shackles, crossmembers, linkages, modify the steering, etc. So unless you are a GREAT fabricator this is way more work than it's worth. It is NOT a bolt in swap! As we've said several times now, it will be MUCH easier to swap over the body. Bodies should swap with very minimal fabricating. All you might need to do is modify the trans tunnel. The rest is essentially bolting everything together. You'll probably want to have a torch. There is sure to be a bunch of rusty bolts that will give you trouble.
Quick Reply: 4wd swap
