Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
'05 Escape...now no start?
Old 11-28-2015, 10:40 PM
AerostarDad's Avatar
AerostarDad
AerostarDad is offline
I have a 2005 Escape, 3.0L, 2wd. Wife said it was running rough intermittently, so I replaced the fuel filter(hadn't been done in a while). After the filter change, it started and warmed up just fine...backed it out of the driveway, drove to the corner and the engine died, and would not restart. I pushed it back home, checked for fuel at several locations (filter in, filter out, fuel-in at fuel rail under hood), all had fuel supply. The vehicle has 160,000 km's on it, so I assumed worn-out fuel pump. Replaced the pump, and will still not start. Any advice would be appreciated.
Also, what's the difference between the fuel pump for the "Onboard Refueling Vapor recover system" and the fuel pump for a vehicle not having that system?
Thanks all!
Old 11-29-2015, 07:01 PM
scott91370's Avatar
scott91370
scott91370 is offline
No check engine light?
Old 11-29-2015, 08:15 PM
AerostarDad
No CEL. No codes either. Used a friends Snap-on code scanner. We pulled a plug to check spark...we get a nice big spark once, then nothing.
andyy
01-01-2017 01:12 PM
moonlightdriver
07-16-2016 11:39 AM
sharpblades
04-06-2014 08:57 PM
AFoster1025
1997-2006 Expedition & Navigator
10-25-2010 05:48 PM
Farmall05
03-17-2008 07:34 PM
Quick Reply: '05 Escape...now no start?
