Headlight Problem and Random Connector Under Dash?
Old 11-26-2015, 08:02 PM
DaMonsterMonster's Avatar
DaMonsterMonster
DaMonsterMonster is offline
I have a problem with my headlights on my 93 f150. When I turn them to the low beam position the high beams are on as well as the high beam indicator, in the high beam position the low beams come on and the high beam indicator is still on. In the pulled back high beam flash position they stay on high beam and of course the high beam indicator is on. In low beam the drivers side headlight is a lot dimmer that the passengers side.
Other thing is there are a couple connectors under the dash that aren't plugged in and I don't see anything that goes to them. I have pictures and will upload soon. Thanks!
Old 11-26-2015, 08:04 PM
DaMonsterMonster
Imgur: The most awesome images on the Internet should be all of the photos. Can get more if needed. Also my license plate light was missing. Put a new one in and it's also not working. Could that plug over the hump be the cause?
Old 11-27-2015, 06:55 AM
subford's Avatar
subford
subford is online now
Sounds like a bad body ground. There should be a 10GA or larger wire going from the NEG post of the battery to fender. Make sure it has good connections on each end. The large battery NEG cable goes to the engine block. The frame does not have to be grounded in most cases but the license plate light is an exception to this along with the trailer plug at the rear and they use the frame for a ground. The large NEG battery cable should have a clamp half way to the engine and the clamp is bolted to the frame for the frame ground.
The plug under the heater control in your first photo is for the trailer brake controller.
In the second photo is the Warning Chime Module plug.
As for the Drivers side next to coolant reservoir there should not be a M/F plug in this area.
Old 11-27-2015, 06:10 PM
DaMonsterMonster
Yea it looks like a bunch of 3 wire splices. One of the wires is cut in one of them. So bad ground would reverse the high and low beams?
Old 11-27-2015, 07:06 PM
subford's Avatar
subford
Bad grounds do funny things.
Old 11-28-2015, 04:21 PM
DaMonsterMonster
Very true. ..
Old 11-29-2015, 08:23 PM
DaMonsterMonster
Headlights work normal now. Two outer wires on the plugs were switched. That wiring mess must have been for aftermarket light s a previous owner put in because there is a KC Light switch on the dash. Haven't looked into the license plate light a whole lot yet. Thabks for the help on the plugs! Those worried me a bit. Was kind of hoping they with to the climate controls cause it is stuck on defrost and the blower motor only turns on on high (bearings are going out in it is probably why it won't work in any other mode than high)
oft
10-17-2014 08:46 PM
sooboy460
07-08-2014 04:29 PM
selym22
07-16-2012 10:45 AM
riggz
1999 to 2016 Super Duty
05-13-2009 11:18 PM
houghda
07-03-2007 07:04 AM
Quick Reply: Headlight Problem and Random Connector Under Dash?
