1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Dash Pic
Old 11-26-2015, 11:17 AM
Jterr's Avatar
Jterr
Jterr is offline
Dash Pic
Just got a replacement dash from a 2004 for my 2003 F-350 and it has a hole (see pic); what goes there as mine doesn't have anything there.
Old 11-26-2015, 12:51 PM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
4X4 switch and pedal adjustment switch.
Old 11-26-2015, 01:49 PM
Jterr's Avatar
Jterr
Jterr is offline
Thanks, guess will have to make a plug/cover out of old dash....
Old 11-26-2015, 02:04 PM
noober0x's Avatar
noober0x
noober0x is offline
Side question... Will a 2004 dash fit in a 2002 truck?
Old 11-26-2015, 02:07 PM
Jterr's Avatar
Jterr
Jterr is offline
should I think it goes 99-04
Old 11-26-2015, 04:42 PM
noober0x's Avatar
noober0x
noober0x is offline
Sorry, I meant the newer 2005 version with the nifty a/c vents.
Old 11-27-2015, 11:26 AM
Magnolia Tom's Avatar
Magnolia Tom
Magnolia Tom is offline
That dash is from an 05 I think. That hole is where the 4wd switch, rear power slide window, and reverse sensor switch would go if you have any of those things. There is a write up on switching the dash from an 05 and up to an earlier model. Not a plug and play mod.
Old 11-27-2015, 07:59 PM
Ginther's Avatar
Ginther
Ginther is offline
Originally Posted by Magnolia Tom
That dash is from an 05 I think. Not a plug and play mod.
+1
A 2005-2007 dash is not a simple conversion for 1999-2004 trucks. I tried to do it on my 2004. Instead I wound up going with an Excursion upper panel and an 05-07 center lower. Worked out well and was relatively easy.
mark MANGERSON
04-22-2019 10:13 PM
fordka
Ford Truck Parts for Sale
01-15-2018 09:28 AM
spoolen&smoken
6.4L Power Stroke Diesel
04-12-2013 11:08 AM
mrqb22
03-01-2010 11:26 PM
Quick Reply: Dash Pic
