Shaking
Old 11-24-2015, 02:19 PM
Wes Shaver's Avatar
Wes Shaver
Wes Shaver is offline
Shaking
Have a 2004 Fx4. Lately its been shaking violently when i accelerate. when i turn the overdrive off it stops. Any thoughts?
Old 11-24-2015, 02:53 PM
07F150Lariat5.4's Avatar
07F150Lariat5.4
07F150Lariat5.4 is offline
Mine did the same thing and ended up being the spark plugs misfiring. Have the plugs been changed?
Old 11-24-2015, 03:05 PM
Wes Shaver's Avatar
Wes Shaver
Not yet. That was the first step I was going to take. Why would it only shake when overdrive is on?
Old 11-24-2015, 05:41 PM
07F150Lariat5.4
Failing plugs usually will misfire when under load only. Does it get worse as you hit a hill? Mine shook like crazy in O/D going up hills at 45-50 MPH and when I took it out of O/D to take low RPM load off of the engine, it cleared up right away. I can almost guarantee your issue is the same one I had. I replaced my spark plugs and it hasn't happened since. That was 44,000 miles ago.
One thing I want to mention; If you're not familiar with the spark plug design on these year 5.4s. These are not your regular spark plugs. They have a 2 piece design and the bottom piece of the plug is a porcelain shell that can break off in the head during removal due to carbon seizing it into the well. There is an extractor tool by Lisle part #65600 to extract the shell. There are some good videos on YouTube showing proper procedure for spark plug removal, shell extraction with the Lisle tool, etc. I also recommend running a few tanks of Chevron Techron before tackling this job, which will help to break loose the carbon from the porcelain shell.
Old 11-25-2015, 01:56 PM
Wes Shaver's Avatar
Wes Shaver
It does get worse going uphill. In fact it starts to shake on the exact same spots on my way home which are hills. Thanks a bunch for the input!
Old 11-25-2015, 09:25 PM
07F150Lariat5.4
No problem! Hopefully should fix your issue. Pretty confident it will.
Old 11-25-2015, 09:54 PM
davidzog's Avatar
davidzog
davidzog is offline
I had the exact problem a few months ago. Changed the plugs and all has been well for 4,000 miles. I used original motorcraft plugs as i read here that after market plugs xometimes failed...good luck.
Old 11-26-2015, 11:58 PM
sccowboy's Avatar
sccowboy
sccowboy is offline
Yep, plugs should clear you right up. I bet if you hooked up an obd reader and observed misfires, you'll see the counts increase as it shakes. Plug change out is a piece of cake just take your time and keep the beer cold and plentiful!
Old 11-27-2015, 09:42 PM
dfishrmn88's Avatar
dfishrmn88
dfishrmn88 is offline
Would this throw a code? My is doing the same thing but doesn't show problem codes. I cleaned throttle body and MAF, changed fuel filter, cleaned air filter, etc. and it still shudders under acceleration.
Old 11-28-2015, 09:03 PM
sccowboy's Avatar
sccowboy
sccowboy is offline
Not necessarily. You may see Misfires on your scanner. The plug change isn't the nightmareiit's made out to be.
Thumper47
1983 - 2012 Ranger & B-Series
03-23-2019 01:51 AM
powerstroker100
1999 to 2016 Super Duty
19
05-11-2016 06:27 PM
Dwayne42
2004 - 2008 F150
68
09-13-2014 10:35 AM
makuloco2000
11-20-2013 08:43 PM
jbarefoot
03-04-2011 05:52 PM
Quick Reply: Shaking
